Comma-separated logging in World Radio League allows you to log multiple operators at the same location without entering the same contact information multiple times.
This is especially useful when hunting POTA stations where two or more operators are activating the same park.
How Comma-Separated Logging Works #
When multiple operators are at the same location, enter their call signs in the Call Sign field separated by a comma.
For example:
KG4VET,KJ4ULZ
World Radio League will recognize each call sign individually while allowing you to enter the shared contact information only once.
Logging Multiple Operators #
To log multiple operators:
  1. Open or create the logbook you want to use.
  2. In the Call Sign field, enter the first operator’s call sign.
  3. Add a comma, then enter the next operator’s call sign.
  4. Enter the shared contact information, such as:
    • Frequency
    • Band and mode
    • POTA park number
    • Other applicable contact details
  5. Click Log Contact.
World Radio League will automatically create a separate QSO for each operator using the information you entered.
Using Comma-Separated Logging for POTA #
This feature is particularly helpful when hunting POTA activators.
For example, you may work one operator at a park and then hear:
“Stand by for second op.”
Instead of logging the first operator and then entering the park, frequency, and other information again for the second operator, simply enter both call signs separated by a comma.
The shared park and contact details can then be used to log both QSOs at once.
Available Across WRL #
Comma-separated logging is available across the World Radio League:
  • Web app
  • Desktop app
  • Mobile app
This makes it useful whether you’re hunting POTA stations from your home station or logging contacts while operating in the field.
Comma-separated logging saves time when contacting multiple operators who share the same operating details. Simply separate their call signs with a comma, enter the contact information once, and WRL will log each operator as an individual QSO.
For POTA hunters, this can make working multi-operator activations considerably faster and eliminate the need to enter the same park information multiple times.
