User Guide: Connecting WSJT-X with Your World Radio League Account #
This guide walks you through setting up WSJT-X so that it streams your contacts directly into your World Radio League logbook.
1. Sign Into World Radio League #
  • Open World Radio League and log into your account.
  • Keep this window open while you configure WSJT-X.
2. Open WSJT-X and Preferences #
  1. Launch WSJT-X on your computer.
  2. Navigate to Settings / Preferences.
  3. Connect WSJT-X to your radio.
    • ⚠️ Important: WSJT-X should remain the only application connected directly to your radio, unless you are using a virtual port software.
3. Copy UDP Server Port #
  1. Inside the Reporting tab of WSJT-X, locate the UDP Server Port number.
  2. Copy this number — you’ll need it in the next step.
  3. Click OK to close preferences.
4. Configure World Radio League Desktop App #
  1. Open the World Radio League Desktop App (Or WRL Integrations App).
  2. Select CAT Control & UDP
  3. Under UDP Port, paste the port number you copied from WSJT-X (if different from the default).
  4. Choose the World Radio League logbook you want to send contacts to.
  5. Click Start Listening.
    • ✅ Do not connect the World Radio League Control app to your radio — it should only stream contacts from WSJT-X.
  6. Leave the app running in the background (you may minimize it).
5. Make and Log Contacts #
  1. Operate WSJT-X in your chosen mode (e.g., FT4 on 20m).
  2. When you complete a contact, confirm by clicking OK in the WSJT-X logging window.
  3. Open your World Radio League Logbooks section.
  4. Locate the logbook you selected earlier — your contact will appear there automatically.
Quick Tips #
  • If you want to use WSJT-X, WRL, and GridTracker together, check out this guide!
  • Always keep WSJT-X as the primary link to your radio, unless using a virtual port software.
  • Run the World Radio League CAT Control app in the background for logging.
  • Double-check UDP port settings if logs are not appearing.
