Every logbook in World Radio League is customizable — from its name and location to radio, power settings, and even contest configurations. Editing these settings helps ensure accurate logs, tailored exports, and a smooth operating experience.
This guide explains how to access and update your logbook settings.
Accessing Logbook Settings #
Go to the Log Contacts page
Select the logbook you wish to edit
Click the Settings wheel (⚙️) in the top-right corner of the logbook interface
You’ll now be on the Logbook Settings page, where you can update the following fields.
Editable Fields #
Logbook Name & Description #
Logbook Name: Change how the logbook is labeled in your dashboard
Description: Optional text to describe the purpose of this log (e.g., “CQ Worldwide SSB 2024” or “Mobile Operations Log”)
Logbook Style / Template #
Choose from available templates to determine which fields are visible in the logging interface:
Default WRL
All Fields Logger
POTA Logger
More templates may be added in the future.
Changing the template customizes the logging experience without affecting existing entries.
Operating Location #
Set a default operating location (e.g., “Home,” “Park,” or GPS grid):
If set, all future contacts logged in this logbook will default to this location.
If left blank, you can select the location during each logging session.
This setting does not retroactively apply to existing QSOs.
Equipment Settings #
You can define default equipment used for this logbook:
Radio
Antenna
Operating Power (Watts)
Like location, these settings only apply to new contacts logged after the change.
Callsign for This Logbook #
Use this to override your default call sign for a specific logbook.
Commonly used for:
Club callsigns
Special event stations
Any QSO logged will reflect this callsign in exports (e.g., ADIF files)
Operator Field #
If operating under a club or alternate callsign, you can enter your personal callsign here to show who actually made the contacts.
This is especially useful for contests and multi-operator activations.
Contest-Specific Settings #
If the logbook is being used for a contest, you can configure:
Power Category: e.g., QRP, Low, High
Assisted / Unassisted
Number of Transmitters
Band Category: e.g., Single Band, Multi-Band
These settings will be used in Cabrillo exports and in WRL’s real-time contest tools.
Saving Changes #
Once you’ve made your updates:
Click the “Save Settings” button at the bottom
A success message will appear: “Updated Successfully”
Return to your logbook to see the applied changes
Important Notes #
Settings like location, radio, or power apply only to new QSOs going forward.
Past QSOs remain unchanged — if you need to update those, use QSO Manager with bulk editing tools.
Logbook Settings allow you to:
Personalize each logbook by name, purpose, and operating configuration
Set contest categories and operator info
Adjust export behavior for special events or club use
